Rotary vortex clearance
do i need to turn off homing option in the g sender when using the vortex rotary tool?
i mount the rotary tool to the bench and the machine wants to home (front left corner)
if i were to accept the request the spindle gantry will crash into to rotary tool.
30x48 mk2
spindle
g-sender
rotary vortex
rotary tool is mounted level and in the same plain as the MK2.
thank you,
Dan
For that reason I changed my homing position in setup to rear left & moving the Y axis homing sensor to the back left.
Allows me to realign Y axis ( making sure router is clear of Vortex head & tail stocks) by running into the front legs instead of the back.
Russ
Russ,
thank you for the quick response.
I got into the habit of always homing the machine before sending it to the project file.
I like that idea.
on it
thank you,
Dan
