Oops
I have been working on a project where I saved the project to a .nc file. But , I neglected to save the c2d code (using carbide create). I want to make a few changes.
My question: is there a way to get the c2d code from the .nc file? Or will I have to recreate the project?
thanks
Larry
@bubalarry You may be able to use gcode ripper to create a .dxf file, but I don’t believe that you will do better than that. Even then, from what I’ve read, the .dxf file may not be what you started with.
I’ve moved this to the carbide create topic to give it more prominence.
You may want to ask this on the carbide create forum, too.
