SLB action buttons
Hello!
I’ve been using gSender and your auto zero touch plate for a little over a year now. I’m a huge fan of both. Thank you! Recently my XPRO V5 died on me. Because of the excellent products I already had from you I purchased a SLB. At the same time I updated to the latest version of gSender. I’m very happy with both. I would like to suggest and update that will allow me to program a macro for the action button that will allow me to use 1 button to toggle the powered aux 1 output (P2) off and on. I am using that output to turn my vacuum on and off. It works flawlessly when I start and stop my CNC. I would like to also be able to toggle my vac off and on when my machine is not running. There are a couple of threads (one of them mine) regarding this but it seems there may be a limitation in the code the macro will run. If so, can you update gSender to allow me to do this?
Thank you
Hi @JeffW this is a great suggestion! I will say that this is actually a limitation of the SLB firmware and not gSender so I’ll move this to the SLB category - but I’ve noted it down and hope we can implement it one day
