SLB alarm inputs
I do not have my Altmill yet - hopefully March time frame. In the meantime I am trying to learn and figure everything out ahead of time. I think I have read every document on the Sienci website. However, I have not been able to figure out one thing…
My existing machine is a home built 15x34 machine with a 2.2Kw water cooled spindle. The chiller used for the spindle water supply has an alarm output (NO or NC) that I have tied into my limit switches so that, should I loose coolant, the machine STOPS.
Can I use one of the AUX limit switch inputs for this? If so, how/what settings are needed to use it?
Many thanks,
Len
hey Len, I’m not an expert on this sort of stuff but have you read this part of the SLB documentation? Technical Manual - SuperLongBoard
Kelly, thanks for the reply. Yes, I have read the SLB documentation front to back and have not found an answer yet. There has to be a way. If I read the documentation correctly, the AUX limit switch inputs are tied to the main XYZ limit switch inputs in the center of the board. The regular XYZ limit switch input wood have to be Normally Open in order to use the AUX inputs as additional limit/alarms. When I get the machine I will be experimenting for sure.
@Lenp that’s an interesting idea, I’ve not come across something like that before. Speaking off the top of my head, it seems like something that should be feasible and yeah I’d probably set it up as a ‘limit switch’ input. Like you say it’d have to match the other limits switches as NO/NC that you’d be using as actual limit switches, and the only other thing you’d need to do is enable ‘Hard Limits’ and that would immediately stop the CNC whenever you’re doing something if the ‘limit switch’ gets triggered
I think I have it all figured out! I have the Haunyang (water cooled) 2.2Kw spindle hooked up and controlled via RS485. Chiller alarm is connected to the “A” limit (and GND) and it works great. Pinch off the flow and machine stops immediately.
Also using the PWR2 output to control the chiller and dust collector.
Had to insert a time delay relay in the chiller alarm output because the alarm output is “active” before and immediately after power up and remains active until water flow is detected (a few seconds). Had to use the time delay on the old MACH3 machine as well. Wiring diagram available if anyone wants it.
Lenp
