I notice in Gsender for my 48x30 There’s this slb connection should I use this or connect to my 48x30
Instead I notice when I connected to the SLB on G sender I don’t get any errors or errors when I’m homing not sure if this makes a difference
When you connect, just make sure you select “grblHAL” as the firmware, and then otherwise you can have 48x30 selected and everything should work well for you
