SLB Enclosure/case Model accessable anywhere?
Is a copy of the SLB Enclosure model (image) accessible anywhere?
Ive looked around and cant see one and thought id check before start measuring it to sort out mounting it
Hey Fireblade,
I found the SLBext enclosure on onshape. I have no idea if that one is the same as the SLB for the longmill, nor do I know if you have the former or the latter.
It might be helpfull, it might not.
Here ya go
thx, looks very similar, and without checking measurements is probably the same extrusion,
Just to expand on @Spamming_Eddie excellent referral, you can always find our designs in our ‘open source’ sections of our documentation, or by searching our company’s OnShape postings (like the one he listed), although I will say that just looking through things I’ve realized that the MK2.5 is still not live and thus the SLB by extension isn’t yet there either so I’ll add that to my todo list.
Since the SLB is a bit of a different form factor than the SLB EXT, I’ll post the files here for your use in the meantime:
SLB Enclosure.step (2.3 MB)
SLB E-Stop Assembly.step (4.9 MB)
