SLB-EXT Alarm 10 on startup everytime
I just purchased the Closed Loop Motor set for my Longmill MK2. Everything works after tweaking some things in the config section. But the only thing I keep running into is that upon startup, my machine is throwing an Alarm 10.
The thing is, my Estop isn’t pressed in. To clear the alarm, I have to press the E stop, and then the alarm will reset after clearing the E stop. Is this just a new feature with the EXT?
Everything is up to date. I have tried both the new Estop and the old Estop from the SLB. All wires are secure and in the right place.
@dehoutwinkel Yes, this is a feature (not a new feature) of the SLB-EXT. If you power cycle the SLB-EXT, you need to reset the e-stop.
Excellent, thank you!
