Super longboard won’t power up
I just received my SLB but it won’t power up. My original longboard works fine
Can you provide some more background? What process did you go through when you got it then hooked it up
If you bought the complete unit, then you should be able to check the power supply by plugging it into the original LongBoard as a sanity check. Also make sure you flip the small power switch at the back of the SLB
This topic was automatically closed 15 days after the last reply. New replies are no longer allowed.
