Tool database - copy tool to another folder
Using CarveCo Maker.
I must be missing something simple, but how do you copy a tool to another folder in the Tool DB? Example: I set up my bits (have some from multiple sources) in a folder for soft wood (MDF, Plywood, etc), but want to create another folder for the same bits but with settings for hardwood, and another for acrylic, etc. I cannot for the life of me figure out how to do that.
In the project window select Toolpaths and then below that section, you can select the Tool Database. After you open your tool database you can select “add group” and then “add tool”. You can highlight one of the bits you are wanting to create an alternate for and click copy. All is done in the tool database window. You can click and drag bits and folders too.
My bad. I didn’t think drag/drop was working, but it’s just a graphical UI thing in the window. didn’t behave like typical Windows drag/drop (icon didn’t change during the drag so I didn’t think it was actually dragging). Doh!
