Tool length sensor and probing wiring question
On my Altmill 4x4 with the superlongboard, the new Sienci Labs autozero touchplate connected to the 2 terminal probe outlet works just fine, now I have added the rapid change Solo tool changer with their tool length sensor which operates on 12-24 volts. The three wires on the tool length sensor are red, black and yellow
If I am reading the super longboard technical manual correctly, it states it is ok to connect the 3 wire tool setter to the back of the super longboard controller TLS 3 pin outlet
Is that the proper way to connect it ??? what colored wires go where ?
