Has anyone hooked up a tool setter off of amazon to the altmil. I trying to set mine up and was wondering if its a pain
There’s not much to it. Just have to figure out which 2 of the 3 wires are the normally open pair.
I thought it was normally closed.
Actually, you are correct. I just checked my config and I have my touch plate pins inverted. It’s been a while since I set that up.
How and what port did you use?
You can use the 2-pin probe port, and save the 3-pin TLS port for a powered 3d probe.
Play with gSender probe inverts options until you have it working properly.
