Skip the weeks of setup and test cuts. Everything is ready to cut, so you can go from opening the file to cutting a full 32-piece set in minutes.
My own independently developed project, designed and tested on my AltMill 4×4. I handle all support and purchase questions.
Included
- STL files for all pieces and board layouts, plus alignment-hole DXFs
- VCarve Pro files with all toolpaths, tabs and alignment holes set up for both sides
- Step-by-step PDF guide
- VCarve Pro / Aspire 12 or newer: open, select your tools, recalculate and cut.
- Other two-sided CAM (Fusion 360, Carveco, etc.): use the STL files and follow the guide to set up the job.
You’ll need: hardwood at least 38 mm thick and planed flat, a 6 mm end mill or compression cutter, a tapered ball nose, and 10 mm dowels. About 14 hours of machining for the full set.
Personal (for yourself or gifts) or Commercial (if you sell the sets you make), with
25% off until 13 November.
Shop (Personal and Commercial versions): https://www.etsy.com/shop/ReadyToMakeDesign
