just wondering if anyone know if ugs platform has a file size limit i tried to load in a finish toolpath but it seems to not load in anything i think it could be to big for some reason.
Usually it can struggle with much larger files, this is also dependant on the capability of your computer running UGS. Most times though if you give it some time then it should load. I’d recommend if you’re planning on doing lots more contour finishing tool paths that you get a more powerful dedicated machine otherwise you can certainly run into issues with running really large files
