Made this simple support for the vacuum hose, scrap 1/2" plywood for the bracket. Cut a plug to fit inside of 3/4" PVC, jb weld in place, drilled it for rounded garage hook. 2 1/2" screws hold bracket to ceiling supports, simple hose support, sprayed it black, done deal. You can see the ground wire within the vacuum hose. Also I can fold it up towards the ceiling to get it out of the way when not needed.
