@RonRowland Use the cogwheel at the top right to open settings, then it’s under the spindle/laser tab.
My offset settings just show 0 & 0
@Drebz Yeah, they start at 0, 0, you have to enter the offsets for your machine. To find your offsets put a v-bit in the router and mount the laser if not mounted. Mount a piece of scrap or use the waste board for the next part. Zero X and Y over the scrap an your Z to the surface of the scrap. Now you need to make a small dot with the router in the scrap. Then without changing the zero’s jog until the laser dot is exactly over the router dot.
At this point the offsets are displayed in gSender as the X and Y coordinates. You put those numbers into the settings for the offset. If that doesn’t work right then you might need to put in the opposite off what is displayed. When it’s set up and working then switching between laser and router in the bottom right of gSender should set the zero for you.
Hope that makes sense.
Michael
Go to File then Export and you have a choice of file types including SVG.
