Vectric pro files show up tiny on vizualizer
when I load a file created in Vectric to Gsender it shows up very small, file text is 7 inches wide but shows up on gsender visualizer as about 1/2 inch wide. Help
I wonder if you got mm/inches mixed up somewhere? Post-processor maybe? GRBL (mm) instead of GRBL (in)?
@charles I use a Wheel mouse with the roller wheel on top, I can zoom in and out with the wheel. Take a look at the small 3D box in the lower right corner of the visualizer and click in the center and see if that helps.
I have this same issue. Was there a resolution that worked for you? I have everything set to inches but a file that might bee 12 inches in Vectric shows up as 1 inch in Gsender. Please let me know if you were able to correct this.
Tanks
