- Firmware version: I’m guessing 5.0.3 but I can’t update
- Sender: gSender
- Relevant tested files: not gcode related
- Any pictures or videos attached showing the issue:
- Upload of the ‘Diagnostics’ PDF file:
Steps to reproduce:
Issue only happens through gSender.
Slide the spindle scale and the vfd only speeds up to, roughly, half the speed that gSender says.
I’m not sure if my wiring is correct, aside from the slow speed it works as expected.
The vfd I have is the PwnCNC 110v air cooled.
I already reached out to PwnCNC and they aren’t sure about the settings for the slb.
I don’t know if it’s related, but if the spindle has been activated by gSender but speed is 0, it seems to jog the spindle and the vfd flashes 150 ish.
