Only using the vortex, I’m constantly getting code 19, last g sender, and running the latest firmware SLB EXT?
@bmor02 What is throwing the code? I don’t see an error code 19 in the list of error codes? Is this an error thrown by gSender?
Alarm 19 or error 19?
Error 19 does not make much sense in this context, in that it’s an error related to eeprom (non-positive value where a positive value is expecteD)
Alarm 19 is spindle Modbus communications.
I can use the machine all day cnc normal I jump to vortex it will cut for a few minutes and stop with code 19 I check all my connections and the main thing is not happening with normal cnc jobs
I just purchased the controller from you guys I was told that the firmware is updated before you guys send it to me
Does is possible to remove the code from triggering in gsender or the firmware?
Hey bmor,
Have you installed the rotary using the manual concerning the closed loop rotary?
Thanks for the input. I don’t believe my issue is with the closed-loop motor
I believe that answer to be no.
Okay succes with your enquiry. I hope you can get it resolved.
