Just as I posted on the FB Group, I’m trying to collect info on what the most common sized dust shoe hoses are that are being used or that maybe would be most preferred. I’m trying out a new design right now for the LMs dust shoe and I want to make sure it’s easily adaptable to all setups.
I would love some feedback from you guys. If you could take 5 minutes to go to your LongMills and measure the inner and outer diameter of the hose you’ve got hooked up to your machines, that would be most helpful. Or alternatively, let me know what size hose you’d prefer over your current setup.
The hose I use is 1 3/4" OD on one end and fits perfectly inside the dust shoe connector. The other end is 2" and fits perfectly over my Dust Deputy input connector. The output on the Dust Deputy is slightly tapered and accepts the 2 1/2" shop vac hose. I couldn’t ask for anything better. Maybe taper the connector to accept different size hoses.
@chrismakesstuff Chris: I am using a 2 1/2" ID dust collection flex hose that fits onto a hard ABS connector. The connector is 2 1/2" OD and 2 1/4" ID. All parts came from Lee Valley.
The connector presses snugly into the hole that I milled into my dust shoe.
For me, the beauty of this setup is that I can attach the other end of the flex hose to a 4" to 2 1/2" adaptor, which, in turn fits into 4" PVC pipe. From there, a 4" flex hose connects to my dust collector.
