I can’t load GRBL to use my laser machine Because my laptop is runing windows 11 S mode can anyone help me with this problem thanks
@Jackie Welcome to the group, Jackie.
I just did a quick net seach and came up with several sites showing how to disable S mode. You should have no trouble.
I’m not sure what you mean when you say that you want to “load grbl”. You don’t “load grbl” onto your controlling PC. grbl is the software that is loaded onto the CNC machine itself, many of which are using an arduino uno as the brains. It takes the code from your controlling pc and uses it to run the project.
So, if you can be more specific about what it is you are trying to do, I’m sure someone here will be able to help you.
You will also get more replies if you post what your machine is and what you intend to use as your CAD/CAM application.
