So, I see the “out of stock” replacement design T8 antibacklash nut! With the MK2 48x30, is there going to be a new similar design for the T12 anti-backlash nut? I have fiddled and adjusted the existing nut a lot and still can’t stop the binding skipping. Especially with the bad wobble of the x axis screw. Would seem something is needed to reduce the wobble which leads to binding skips ruining the carve.
Vinny, dont know about plans for the T12 nut but I put quite a bit of tension on the leadscrew lock nut which prevents the wobble.
