Y-Axis Gantry Alignment Tip
After mounting the Y-axis gantries to the XZ rail and taking measurements with my precision engineer square, I noted that no matter how I bolted things together (and I tried various bolting sequences…) the right side gantry was not aligned at 90 degrees (as viewed from the front) to the rail. I believe this is mostly due to the somewhat imprecisely-bent steel L brackets.
To fix this problem, I did what I have found works for setting up all my other machines: shim between the parts that need to be moved further apart.
Because the commercial shim material I have is too thin, I elected to make my own. As you can see, it’s something that you’ll probably have on hand: a pop tin. Just cut yourself a strip, then use as many layers as necessary. How’s that for a simple fix?
Marty
Kingston, Ontario, Canada
I might try this. I have same problem but on both sides which caused rear v-wheels to pull in and up. I used extra washer on each rear excentric nut and that aligned the wheels. I figured if the discrepancy was static (zero is still zero) this wouldn’t affect accuracy of cuts but I don’t know that for sure.
[content removed by author]
I’m not experienced enough to gander a response about the aluminum vrs steel rails issue you’re raising. It woud appear that you have precision milling equipment at your disposal, or else you wouldn’t even be thinking of swapping them out. From my perspective, the delrin V-wheels aren’t such an Achilles Heel. Yes, they’re a consumable commodity, but so what? I mean, how often are you having to replace them now? Of course it all depends on hours of use, but as I’m no longer running a woodworking business, I’m happy with how it’s all working out for me.
Please keep us in the loop af this all plays out.
@Blunderpunk I realize this is old but curious about your project, any news? I have been Looking at replacement wheels and this I might give this a try CLICK
Any Thoughts? I even thought of these as possible replacements but wonder about them being so much harder than the aluminum rails CLICK
Hey Bill, did you ever try those extreme polycarbonate wheels? I’m very interested in this as I may be upgrading to an 80mm spindle… weight is approx. 12-13 lbs and I want to limit any deflection. Thanks!
@ThisLittleWorkshop Yes I did try them, I am now using them on the tops to support the weight and use the standard Delrin V-wheels on the bottoms and the reason is it’s easier for me to get the proper tension on the the bottom wheels, it’s the way I adjust. When I had them on both tops and bottoms it made it difficul to adjust, they are very hard indeed.
Bill
