Y axis jamming when giving coordinates but not while homing or jogging
I tried updating the firmware on my MacBook 14.5 but I got an error so I’m still on 5.0.3. Hopefully that’s not the answer
  1. Firmware version: 5.0.3
  2. Sender: gSender
Steps to reproduce:
type in coordinates of -400, -400 and the x axis moves perfectly while the y stops and grinds. I can move them independently just fine at 4000mm setting and they home simultaneously every time. gSender acts like it moved the y to the correct location but it hasn’t moved but a couple mm.
gSender-firmware-settings-8_6_2024-9_20_17 PM.json (2.8 KB)
I’ll also occasionally get the z axis to only want to move down when positive is pressed. It also makes this grinding noise like it’s struggling. Occassionaly when giving a jog command, the y2 and y1 will fight each other in different directions.
