Hi, I’m a newbe from the UK - Sienci machines are not easy to come by here so alas, I discovered them after buying a competitor. But gSender is great and I love the 3 axis probe. My question, can this work on other makes of cnc provided I use gSender?
If it’s a grbl machine and you know the probe block dimensions it should work fine. Z and XY thickness are configurable in preferences, and all the routine commands are standard grbl-compliant gcode, so as long as it’s configured correctly you should be good.
