Not sure if it was already asked. But if you could just add one additional macro to probing with the 3D Probe it would be awesome. Center Hole probing. Thank you very much guys
Maybe this macro would work for you. It’s for CNCjs but gSender is based on CNCjs so it should work. I know Neil’s macros were used for various things before gSender supported them. His bitsetter macros come to mind.
You should read the macro and set the ‘user defined variables’ to make sure it’s setup correctly for the size of the hole you want to probe.
Hello Michael. Its a very simple macro, so writing it is no problem. But i asked about having it on the probing tab of gSender because they recently added support for 3d probe, but not hole center probing which is kind of the most important one with a 3d probe.
For what it’s worth, I think your suggestion is a good one. I just didn’t know if you were stuck in the meantime.
Happy New Year!
Thanks Michael and wish you too a happy new year!
