Hi, I am upgrading from an opens builds cnc and want to know if I can use the xyz touch plate with the Altmill? If so, how would it be wired as it has 3 wires?
Thanks
Thanks
Hi Serg,
Does the product page for the probe not include instructions on how to use the probe as a two wire probe?
I seem to recall a topic on this with the solution being on the product page, but cannot locate said topic here.
HI SE, I found the write up on using TLS for powering the touch pad and the other 2 wires for on the probe connection. I will try that then update the board. Thanks!
Community, I wired the xyz plate but have an issue with probe function. The Z function works but the next step will confirm the y, once that happens it will zoom further in the y direction instead of going to x. Any thoughts on why this is happening and how to fix?
Hey Serge,
Did you read the section on how to insert dimensions of your probe into gsender?
