4x4 MK2 skewed front right
Hello all - I noticed something weird and not sure how to best approach it. After I assembled my mk2 4x4 and installed base mdf. During intial installation of the t-track and slats. As first step i took 15 degree vbit and marked the max travels on mdf. I noticed that front right of the machine skewed during marking. I thought i screwed up something during mounting of the base mdf so i scrapped everything and had a friend of mine cut out new base mdf and slats on his cnc. Everything came out great but after installing mdf base layer i measured and it seems it happened again. it seems that front right side is skewed out by about a 1mm or so and i can see it as i move the bit front left to right. I also noticed a small gap that is wider at the right front bump stop vs left one. I suspect something is off with the Y2 integrated bump stop sensor but I’m not sure what the correct way to adjust it. Opened ticket with support but also checking here if anyone ran into similar issue and how to best address it?
should I try built in squaring tool in the tools of gsender?
Here is a drawing of what it looks lilke
