Version 1.4.6 with the SLB. Chess pieces that cut perfect on the old control board with 1.2.2 do not cut correctly now. Instead of rotating 360 degrees the pieces only rotates 90 degrees. Rotary surfacing works as it should, so I do have 360 degree rotation. Is there any settings that need to be changed in the firmware or do I need to make changes is the post processor for version 1.4.6. I tried 2 different files and had the same results. It cuts 1/4 of the piece the full length of the item to the full depth.
