Altmill and USB connection
Over the last several months I have seen many posts about dropped connections with USB to controller configurations. I had NEVER had a dropped connecting so I considered myself lucky. Well, all of a sudden I can’t even finish short jobs without the connection dropping.
I have now set up an ethernet connection and am doing testing with that but I am wondering if other people have gone from zero dropped connections to constant dropped connections when overall there was no change to hardware (I did download and install gSender V1.5.0 Edge 8).
It wasn’t a subtle change, it was sudden and extremely annoying.
Anyway, just curious if this has happened to other people or if I just won the USB lottery.
Hi Jens,
My problems had a more sneaking in property to them, going from only sometimes when the air was dry and cold while on long laser jobs, to almost every bloody time, but not every day and sometimes only the first hours after bootup. It had me stumped for longer than it had to, for I stared myself blind on my added 10m length in the usb chain instead of the obvious weakest link. The usb cable provided with the machine.
I’ve looked with horror at the slb and its flimsy usb-c connector. At least the longboard has a proper usb-b to a. I wouldn’t connect the slb with usb longer than needed to establish eth connection. I feel that going with usb on the slb is one way to assure disconnects and frustation.
Why anyone would stick with usb when you have the option to connect via eth is beyond me.
I wish!
I have used the original cable ever since day one without an issue until now. I should put a replacement cable on it and see if that changes things.
I swapped out my USB cable after running into problems on my AltMill and they disappeared.
As reported on another thread, the replacement cable did not help and the issue was determined to be the USB-C port on the controller, most likely a defective solder joint. Unfortunately it is a surface mounted port and several degrees more difficult to repair then a through hole mounted connector. I have reached out to Sienci to see if they would do a courtesy repair/replacement since the controller is out of warranty by now. For now I am operational via the ethernet port on the controller.
Thanks for the update and I’m glad to hear that you were able to connect via ethernet.
Are you connecting the two with a cross over cable or are they both connected to your network? Odd that ethernet seems to be more reliable. Perhaps the rj45 connector is less succeptable to dust or vibration.
I assume that you have the controller connected to your network via ethernet while the panel computer is still on wifi? I am considering hard wiring both into my network and getting rid of the wifi connection on the panel computer. I was just thinking that its one less thing to go wrong…
Can’t speak for Jens or Eddie, but I’m using a regular cat5/6 cable to connect my gControl to the SLB-ext. No cross over cable required.
As for reliability of eth versus usb, it’s not just the cable/connector quality that is important but the error detection and correction that the TCP/IP protocol provides
I have bought me an I5 del win 11 pc and installed it at the machine. I’m still running my longmill mk2 via the old longboard. It can only connect via usb.
I replaced the flims usb cable that came with the machine with a heavy duty gold plated double filtered shielded one (and a spare one in stock), and it holds up, for the moment, but I have found that a usb connection in an electrical poluted enviroment does not take much to break down. I am however raised in a time that if you can smack your device to work for a while longer, you smack it untill you smack it to kingdome come, before replacing it. I have worked around constant weird stalls for over a year before I replaced that one cable.
I bet, I could now run the machine from back in my office without problems, but for some reason, it didn’t occure to me that that small cable could be the culprit. That is untill installing the pc at the machine didn’t fix my problems.
If only someone had smacked me..
This is such a prominent problem with the Windows operating system.
The USB ports are initially set to go into sleep mode after a certain time. You need to go into settings to change the sleep mode to never.
This is so common, Sienci Labs has put this info in their gSender documentation.
I tried to change my usb port to never but could not find where. I followed Sienci Lab’s documentation but it was different on my lap top.
@Jens I know this was an old thread but I just replaced my SLB-EXT since it failed and Sienci replaced it. But now after two jobs of the new one working fine the SLB’s USB connection now connects but does nothing. The SLB ethernet works fine but it seems I got another failed board. These SLB’s are so unstable I am really not thinking I will be investing anymore in Sienci and will not be recommending these machines at all anymore. But I was wondering if you ever got to bottom of this problem. Did you have to get a new board? Or was it something else.
It’s been a while … if I recall correctly, Sienci replaced the controller for me and that fixed my issues. I still have occasions when weird shit happens but all-in-all I completed all the projects I started. I am currently doing non CNC stuff (house maintenance mostly) so I am kind of out of the loop at the moment.
BTW, although I have both Ethernet and USB connected between the gControl and and the SLB-EXT, most of the time I choose to do the actual link via Ethernet.
@Karver_One You should really avoid USB if you can. The connectors are not as reliable as the RJ-45 connector on an ethernet cable. The USB communications protocol is not as robust as Ethernet. And there is a lot of variation in USB cable quality (and some are charging cables only).
Maybe the problem is with your cable and/or the USB connection at the computer end.
Cable management is also important. With the SLB mounted on the Altmill, it is subjected to a lot of vibration. Having loose cables flopping around is surely not good in the long term. Using zip ties to keep cable secure is a good idea.
I don’t know if isolating the SLB from the frame would help.
@chucky Funny you speak of vibration. Last night I was thinking of just that! I actually was thinking of removing the SLB and putting it away from the machine. I can see that these electronics are just so unstable and on the previous videos from Sienci I saw that the CEO was actually looking to buy the electronics for even cheaper. I hope they put some more effort into this area. But thanks for the update Jens!
@Karver_One Reading these forums, I believe Sienci regularly replaces the boards. I don’t know if they are actually defective but it may be cheaper to replace the board than spend a few hours troubleshooting with the client. In any case, I hope they are asking clients to return the “defective” SLB so that they can investigate the failures. It would be a shame to continually replace boards because of a cheap USB connector or other component with a high failure rate.
I swear @Chucky_ott you and I think the same. I actually offered Sienci to take back the board and they said “Dont worry about it” . I am happy they replaced it but with this product failing so often…, it even seemed when I talked with them that this was pretty normal. But I do not know that for sure. I do need a reliable machine, it is made very sturdy but the engine seems to be a Yugo. My greatest worry is that in just a few years when they discontinue this machine like they just did to another one, this will be nail in the coffin for this machine. This will be no long term machine like a nice lathe is. It is just wanting to die. My hope is they will stop putting so much effort in new R and D and start making what they have a more stable and reliable product. Hope your listening Sienci. This could be a great machine.
I’m not sure if this should be a concern. Likely any controller with external drivers and the right power output would work. Sienci’s SLB-ext is used by clients for other vendors’ CNCs. I’m sure other vendors’ controllers would work with the Altmill. Just a different engine in the car frame (to keep your Yugo reference). That said, I’m sure new Sienci controllers would be backward compatible.
At first I used USB to connect my PC to my Altmill and had a LOT of connection issues. I switch to Ethernet and it was great for a few days and then I started having other connection issues. I then discovered that there are different grades of USB cables. I order a high-grade USB cable. After connecting it to my Altmill I have NOT had any connection issues.
I ordered > Amazon.com: UGREEN 240W USB C Cable, 40Gbps USB C Cable USB4.0 GEN3 8K 60Hz PD 3.1 Video Cable Compatible with Thunderbolt 4/3, USB C Monitors, Hubs, Docks, MacBook, iPhone 17/16/15, Galaxy S25/S24, 3.3FT : Electronics
