The videos are impressive - full DOC, 3/4" plywood with compression bit. The comments in the video indicate this is a 2.2kW spindle.
Do you think the Altmill will succeed with the same cut with the planned 1.5kW spindle? Full DOC is essential for compression bits! I don’t mind buying just the AltMill and a seperate 2.2kW if that’s what is needed to achieve the goal.
