Altmill Tramming Issues
I’ve assembled my Altmill 4x2 and did the first surfacing pass. When I went to tram it afterwards, the X tram slope (parallel to the gantry) was about 0.0005 (0.3mm over 23 inches). I was able to bring this to essentially zero using an eccentric bushing on the spindle mount.
The Y axis tramming is a whole different story. The slope was 0.0094 (5.5mm over 23 inches) without the eccentric bushing. With it, I got the slope down to 0.0043 (2.5mm over 23 inches), but that still seems really high.
What could be causing this? What are the next steps to take?
Y axis tramming? Are you referring to nod on the CNC? If so I had to put like 0.012-0.018” shim stock behind my Z axis plate to fix the misalignment. It was off by quite a bit when using only the factory reference grinds on the gantry plates. Now mine is off less than 0.002” on the nod and about 0.001” on the tilt over a 10” distance from the spindle.
Nod versus tilt - How to “Tram” Your CNC Router | Servo Magazine
That’s pretty good on X. Mine was way out, I had to adjust bolts on the left side of the gantry where it connects to my plate.
Use shim stock as needed. Note there’s also 2 bolts to accomplish tramming at the bottom of the Z plate, mine were bottom’d out.
Make sure to check that your spindle moving up and down in Z is moving perpendicular to your X/Y. It is possible to tram your spindle mount, but still have the Z movement out of tram. This would not be apparent in surfacing passes, but would cut tapers in deep holes.
I received my 4x4 altmill in December I didn’t receive the eccentric bushings for making the yaw correction.
Did anyone else get the bushings in their December shipment?
Yep, ours came with two eccentric bushings.
Yaw was simple to adjust out with the bushing.
Nod was another story.
First off, DO NOT USE THE BUSHING to get rid of Nod error. That will mis-align the X motor coupling. Shim the Z carriage to get rid of Nod error.
Ours took .005" shim on the bottom of the carriage.
picked up a set at the open house, and all lined up now.
