So I’m going to redo my spoil board for my Altmill. The first one I did, I purchased the file, set it up in V Carve Pro and proceeded to make the cuts. It turned out ok but the hole spacing is not consistent with each of the slats. When I cut the new ones, should I mount the T Tracks to the base and then place the slats in place, then start the hole drilling?
When I replaced mine I setup a corner fence so I could quickly switch between slats and mill the countersink holes. I did that before removing the old ones. This was on a LongMill but I don’t think that matters.
Doing it that way I just needed to make a file for one slat and they look the same. I also like a grid on my spoil board but that was done separately after everything was fastened down. We are just talking about having it look symmetric right? I like symmetry, often in things that don’t matter, so I can relate.
I’m trying to remember but I believe I marked the table below the slats and installed the T-tracks that way and then mounted the slats. I cut the slats themselves on a table saw and they’re a touch smaller than the T-track spacing so they have a little room for humidity changes and to make replacing the slats easier.
My table is all wood because the LongMill doesn’t come with a table. If you have a solid piece below the slats I think you could do it that way. Looking closer you said base so I guess you do!
Don’t know how unusual this is but I cut my slats on job site saw. I would then put the first slat on the table and fasten it down with a couple clamps. To get “precise” measurements I would then measure the width of the board on the table and use that to put in the CAD software to then precisely locate my recessed holes I wanted it to drill. Have CNC cut the holes and then fasten that slat down. Next would be to put T track in then second slat and make measurements for that second slat and enter it into the CAD software and so on. Following this I had pretty accurate representation of my spoil board in the CAD software. If I had more accurate way of cutting the slats this likely wouldn’t have been necessary since they may have been off by mm or two between slats.
That’s another reason why I installed my T tracks first. My slats aren’t exactly the same width and I figured it would be easier to accommodate minor variation in future slats if they weren’t too tight.
And your not the only one that made a model. I’ve made some different types of 3D printed clamps so it’s been useful a couple of times.
How did you make sure your T tracks were precisely positioned?
@PoppaTim I think that is a good plan.
I used the Altmill to pre-drill the holes in the plywood base for the t-tracks. I also used the Altmill to drill holes in the t-tracks since mine were not pre-drilled.
Then I mounted MDF slats in between the tracks. These don’t have to be precise.
Finally I milled the dog holes in the slats. Milling the dog holes after the slats have been installed will ensure you maintain the dog-hole spacing you want and keep them perpendicular to x and y.
The holes in the plywood for the tracks and the slats are all milled with the CNC. I can reuse the same g-code to mill more slats in the future. I use steel inserts and machine screws to fasten the tracks and slats. It’s better than just using wood screws straight into the plywood.
I fixed a straight edge to my table and then used a tape measure and square. I also drilled the holes, with a drill not the mill, before each screw. Had I more confidence in my mill use at the time I would have used the mill like Chucky. It bothers me when I have something lined up just so and then if the screw isn’t right in the middle it moves it a little. Having a straight edge clamped to the table helped to keep the ends all lined up.
In the end it’s close enough that it doesn’t trigger me. I can be a little obsessive, the office chair I’m sitting in has five legs, one of which has a small mark because after trying them all out I found the one that belongs in the back. That’s normal right? ![]()
