To start off when I make up a project using Aspire for the vortex. When I load an go to run file instead of it cutting the depth it raises an air cuts. Only remedy I found was to load in gsender edge then disconnect from the SLB reconnect and the it cuts project fine. Anyone have this happen? If so what’s the cause Thxs.
