Hi Everyone, New to the LongMill but have had my small desktop cnc since 2016. So not a total newbie but this auto zero is starting to get to me. Hooked it up pretty simple using the new gender edge so it’s on the auto zero plate, start to use it and it either stops way off the work piece or on the plate itself with an error code 5. Any help would greatly be appreciated thanks.
When you are setting up the touch plate, are you using the AUTO mode in Gsender as shown?
@Gerry1 Welcome to the group, Gerry.
Take a look at this video
Please report back on whether this solves your problem.
Yes I used the Auto mode, I also used the bit diameter to no avail
Tried what the video said didn’t work. Evan disabled 13 in firmware still nothing. Just doing Z on the back side is working.
Will do, thanks for trying
Can you capture the console log when you try an xyz probe?
no problem doing it but since I am new to gsender I really don’t have a clue how to do it
After you probe, just click on the console tab in the lower right. Copy the text from the last 20lines or so and paste here.
No just a 1/4 inch end mill
