[Releases 路 Sienci-Labs/gsender 路 GitHub](https://Link from Chris鈥檚 Email)
So, I see that there is a 32bit version of Debian in the release link
I understand that it should work with the PI, because its 32bit, but I kind of just wanted to be sure ![]()
Looks like I GRABBED the wrong file
So a quick Google has re-confirmed what I thought.
the i386 Deb is for an Intel
Going to try the ARM version
DOH!
pi@raspberrypi:~/Downloads $ sudo dpkg -i gSender-0.6.0-latest-linux-i386.deb
dpkg: error processing archive gSender-0.6.0-latest-linux-i386.deb (鈥搃nstall):
package architecture (i386) does not match system (armhf)
Errors were encountered while processing:
ok, so ARM Version is successfully installed.
when I launch it, I still get the same error as last week, only now its in a popup
opt/gSender/resources/app/node_modules/@serialport/bindings/build/Release/bindings.node: wrong ELF class: ELFCLASS64
I also tried to report this issue on the Google Forms.
However, the NEW version is not Listed as an available choice.
Mac and Windows are the only Available Radio Buttons
@Menglor been putting more time in and hope that the new version tomorrow should finally be able to run. Fingers crossed!
