Is it ok to use plywood or should I use MDF?
Flat and rigid is what’s important. The material itself is up to you. There are grades of plywood out there that are flat enough.
@Malcrom Welcome to the group, Troy. As you can see from @Stairguy/Jeremy’s reply, you can expect lots of good support from the members here.
I second Jeremy’s opinion when it comes to the table top itself. If you can find good, flat plywood, it will work fine. For the spoilboard, though, I would stick with MDF. You will be flattening it at the outset and surfacing it from time to time after that. Plywood does not lend itself to shaving layers off of it.
Thanks. I though I’d ask incase there was a reason I keep seeing MDF for the table and not plywood. I got https://www.homedepot.ca/product/purebond-3-4-inch-x-4-feet-x-8-feet-sanded-aspen-plywood/1000861471. Yes I will get MDF for spoilboard :).
Are these a good idea https://www.amazon.ca/gp/product/B07D4C52X7/ref=ox_sc_act_title_2?smid=A3DWYIK6Y9EEQB&psc=1?
@Malcrom If you don’t need to move your table and you have access to all four sides, they can’t hurt. Mine has to be on wheels, owing to space issues.
I have space issues too but level floor issues mostly.
Leveling feet or legs whatever
Adjust for crazy sloped basement floor
I used 1/2 inch sanded 1 side then 3/4 inch mdf on top
