i forgot to change the corner where i wanted to Zero , to be fair i always zero in that one, so can i make it somehow permanent?
also, i feel like the probe goes wayyyy to deep after it found Z , can i change how far down the Z goes after it found Z height, for X Y ? sometimes the material is for example just 5mm in thickness and the Z goes about 10mm deep
Not sure if this is your problem. In settings, go to Safety and see what your height is set to. I set mine to 0 to stop it plunging down and burying the bit in the job or spoil board when homing.
no, when doing X Y Z probe to find corner, after the probe has found the Z, it goes to find X and then Y, now the machine has to go under the found Z height in order to find X Y, that is too deep and i would like to be able to set it manually based on how much my material has in Z thickness
I did find a solution to this eventually.
When finding a corner a first do Z, and the move to the wanted corner, drive the probe down under the material about 1mm and then I let the program find X and Y this way I don’t have to worry about it going to deep under the material and hitting something
