Don’t know if it’s vectric or gsender. I am using the sainsmart 4040 pro. When I load a file into gsender it does not cut as the size I specify. The dimensions in gsender coincide with the measurements in vectric. Help please.
@krodav Welcome to the group.
It’s confusing. You say that the dimensions in gSender coincide with those in Vectric. I don’t understand what the problem is? It would see that the machine is doing exactly what you told it to do.
Look to see if G20 or G21 is called out at the beginning of your gcode. Also is it drawn and expected to be inches or mm? Maybe you selected the incorrect Post Processor? I could help you in a private screen share if you are english speaking.
When I try to outline or run job, both move in about a 10mm space. It should be cutting in about a 300mm space.
@krodav What post processor have you set in your Vectric software?
Is the offer still available?
Check out your workspace too small topic. I have a feeling the last post in it might be the solution to both this and that topic.
Yes Of course, message me or email larrytech54@gmail.com for private help in a Zoom Meeting.
