Ive checked for how to videos on the Sienci website and youtube for instructions on how to operate on my new Altmill set up.
I have the vortex mounted, I probed for Y, no problem but cant get the vortex motor to turn. The videos on Sienci labs refer to a breakout board on the Longmill controller on how to switch over but nothing on switching over on the Altmill.
Can anyone refer me to s specific video on youtube or Sience labs that will show me how to switch over from the regular Y travel to the Vortex ?
I do not have a link for you but are you aware that there are two versions for the Vortex? There is one for the Longmill with a normal stepper motor and there is one for the Altmill that uses a closed loop stepper motor.
Do you have the closed loop version for the Altmill?
The controller for the Altmill does not use any sort of switch-over. The vortex is directly supported.
Having said that, I unfortunately can’t help out more since I do not own a vortex. I am sure that other people will chime in and get you going in the right direction.
Thanks for your help guys, after reading up about the closed loop steppers and the Vortex I now have it working. I had also forgotten the Y cable for power to the Vortex.
just a word of caution regarding the Vortex closed stepper motor, if your power supply is always powered ON, the motor will be powered. I will have to install a power strip with on/off toggles to keep it powered off when not in use
ALL motors should be powered when your mill is on. I never shut my mill off. Very little power is dissipated if things just sit there. I don’t think the motors get warm at all (not tested though)
I might be off in my thinking that the motors are always on - if you were to give a command to stop the holding current, I would think that the motors would be considered to be off. I have never used such a gcode command and although I ‘think’ it’s there, I can’t say that I ‘ know’ it’s there.
