CNC Camera Monitor Plugin
CNC Camera Monitor
Prototype 0.1.8 · gSender 1.7.0-Edge-2 · Plugin SDK 0.2.2
A view-only camera plugin for monitoring USB and compatible network camera feeds while gSender runs a CNC job. It does not access machine controls, send G-code, or change job state.
Hy Bastaaj,
Interesting dev. You mention network cameras here, and in the pluging you even call them ip cameras.
I do have an ip camera plugged into my security system hanging above my machine bed. It’s using the onvif protocol. It is a 24/7 recored feed of the complete machine bed to make sure i can review any oopsy happening and replay it till I know what who and why things bleeped.
I do have a tool to show multiple onvif feeds of my sec system while cutting to quickly review whats happening next door but also to keep tabs on deliveries and clients visiting. It allows me to select a feed to pull it full screen, draw a frame and get a full screen digital zoom of the framed area, and if the camera has the function, mouse tracked ptz movement.
Now most of these functions are luxurious and seldom a must have, but the framedragzoom function does make things easier to stay on top of the area of interest, when using a full bed helicopter view.
Question, does your plugin recognise onvif feeds?
I have a seperate usb camera that covers only part of the bed. I use it with the fireburn camera calibration function to get snapshots of irregular shaped material with mm acurate measurements that can be used inside cad software to design ontop of . Oh how I wish fireburn to recognise my full bed cam, but allaz, it does not. Hence the usb cam. It is however a far cry from the resolution of the ip cam and Cheap is not my middle name because I start fires with euro bills.
Anyhooo, I like your plugin(s) activity. Do you write those old school or is there some kind of Ailien invader involved? Any way, keep up the innovative thinking cap. Yer an asset!
Regards, Cheap.
I consulted the aliens - The gSender plugins operate within a sandboxed browser that cannot directly render RTSP/ONVIF - but they provided me with an RTSP bridge that can run locally on the same machine as gSender - You configure your cameras within it and then use the local URL within the plugin. Should work - I dont have any RTSP/ONVIF cameras to test with. Give it a try and let me know if I need to have the aliens tweak it.
Here is the bridge - https://github.com/bakstaaj/gsender_plugins/releases/tag/camera-monitor-local-bridge-v0.1.0
And here is the updated plugin - Release CNC Camera Monitor v0.1.9 · bakstaaj/gSender-Plugins · GitHub
