Hi,
I am having issues with gSender v 1.62
I am using VCarve Pro
Genmitsu 4040
Also the CNC is behaving odd. When I run the simulator in vcarve pro the file works fine
When I run the file in gSender I receive the errors one is:
the following line caused an error 2: 'G1X3.7997Y7.884270.0180 ā IN gSender.
also the machine at some point has a mind of its own causing it to move the spindle away from the carve in a straight line or jusy bore down into the wood.
