Connect to machine is empty
Last night gSender and my CNC were working great then after shutting everything down Iastnight when I started up today gSender said there was a download and I couldnā€™t continue unless I downloaded the update which I did and when gSender came up the connect to machine field was empty so I cannot use it. The program comes up but there is no machines listed to choose from.
Are you on the latest version of gSender now, v.1.4.10?
Your device may be in the unrecognized devices list now for some reason, could you check out if thatā€™s the case?
Ill close this topic for now, feel free to open a new one if you are still experiencing this issue :slight_smile:
