Connected, but on the screen it says disconnected
My new Vevor 4040 was working fine. Yesterday I tried to turn it on and I connected it easily. BUT, on the screen where it should say IDLE it says disconnected. I’ve flashed it, pressed down on the board, reset the board from the button on the board, and nothing happens. Any suggestions??? Thanks.
Did you figure this out? I’m having the same issue. USB connects fine, but Ethernet conenction says it’s connected but the top banner says DISCONNECTED.
The Ethernet connected box also says grbHAL, while the USB connection says grbl. That’s odd.
I did select the “grbl” fall back in the config.
