Has anyone tried to connect a-spindle and vfd inverter to a longmill MK2 successfully??
Check this out! It might get you pointed in the right direction.
Vince, go to the Add-ons & Modifications section and I put a total instructions on anding the spindle/vfd to the Longmill. It works great!
@VinceC As I believe that your question has been answered, Vince, I am closing the thread. If, after reading the posts that @_Michael and I referred to, you still have questions, please do not hesitate to start a new thread with specific questions.
Trying to add my VFD H100-1.5C2-B1 and 110v 400HZ spindle to SLB (G-Sender (1.5.3)
Can’t find Your full instructions, can you add a link please
Russ here is a link to adding the spindle to SLB. The write up I did was for the old Longboard. This is what I used for my Altmill. I also added the H100 setting that Sienci uses for the VFD setting.
1.5KW 110V Sienci VFD Full Settings.pdf (272.7 KB)
Thank you very much. All’s well. Had my RS485 address set to 0 on VFD (now 2) and black/red wiring switched. ![]()
