Hello,
I’ve just made my third and final tool change. When I went to run the gcode for the final toolpath, I kept getting an error (number 2). When hovering over the question mark, it said all my positions where saved and I could continue with the carve. Unfortunately, it would not let me continue.
So I stupidly shut down gsender think it was a bug, forgetting that with the limit switches I have in place, I need to run a homing cycle. Well, I zeroed my router before shutting down and I can’t move the router or I will lose my position, which is critical on this inlay.
I tried turning off the settings I turned on after setting up my limits but they don’t seem to want to turn off. Is there anyway I can bypass the homing cycle and re-zero my router in the exact position it is currently sitting in?
Thank you,
Rob Schmidt
