I’m using FluidNC and have separate A and Y axis drivers. With “Use A-Axis for grbl” toggled in settings I can run 4 axis operations just fine, but would it be possible to display the A axis controls in the control panel? The only way to have them show now is to toggle rotary mode, which disables the Y axis controls for users swapping the y axis driver over to the rotary driver.
@jomac Keep in mind, Josh, that this is a user forum. It may take more than a couple of days for someone with your setup to reply.
That said, I do have a question. Why did you toggle “use A axis for grbl” in gSender? Is this a requirement of Fluid? I know nothing about Fluid, but I did just read, “FluidNC configuration, however, is very different from Grbl.” So, that is why I am thinking you needed to toggle that switch in gSender.
FWIW, I am running the SLB on a Long Mill Mk1, with the Sienci Vortex rotary equipment. I do not set that toggle, and I do not select rotary in gSender. I have both A and Y capabilities and I can see the A controls in the gSender control panel.
Finally, I don’t know if you will find anything helpful, but if you search this forum for FluidNC, you will find discussions about using FluidNC, gSender and a rotary axis.
Thank you gwilki. Without “use A axis for grbl” toggled, the Rotary “Jog -” and “Jog A+” buttons above the toggle in the settings menu jogged the Y axis. I’m also using the LM Mk1 with the Vortex rotary axis. It looks like the only difference is that I’m running FLuidNC. That could be the problem.
@jomac I think that it’s fair to say that Fluid enters into the issue. With the LM Mk1 and the original longboard, Sienci provided a switch to toggle the Y output to the A motor. It meant that A and Y could not be active at the same time. When I replaced the long board with the SLB, and replaced the Vortex stepper with a closed loop version, the switch was no longer necessary. The SLB runs grbl Hal which can support 4 axes. The SLB has a separate motor driver for the A axis motor. So, now I can have all 4 axes active and gSender shows all 4 axes on the main page.
I’m sorry, but I can’t help you with a Fluid setup. I gather that none of the discussions on the forum were helpful??
Thank you all for setting me straight. I wasn’t trying to offend. It won’t happen again. I meant what I said. This is a great project. I truly appreciate you helping make CNC more open sourced and available to people like me.
In the meantime it looks like I’ll be learning to use grblHAL.
