can i use a regular 1/8" and 1/4" wood drill bit in my cnc router to drill 1/8" and 1/4" holes?
Hi @2Tall,
From what I have read, it’s not really recommended - I don’t remember the specifics, but I think it’s because the minimum speed of the router is still too fast and would cause burning. I think drill bit runout (wobble) might also be a factor.
That said, you could probably try it out and see the results you get.
What I do is use a smaller bit (1/8 when I need anything bigger than 1/8, 1/16 if I need to bore 1/8) and “bore” the holes. The nice thing there is you can bore any size you like in that case, as well.
Others may have tried it out - maybe someone else can give their experience?
Let us know how it goes.
I have “marked” my location with my v bit while doing my carve then drilled it with my cordless drill before. Worked well for what I was attempting to do.
The other problem with a drill bit is the plunge speed is not programable. Along with the speed of the bit spin. I second the 1/8th or 1/16th up cut bits. That would be the best way to cut what you need.
@2Tall If you using vcarve for your work, a good way to drill holes is to use a spiral ramp on a profile toolpath inside the line. This works best if the hole is bigger than the end mill you are using, of course.
thank you elbarsal.
makes sense
thank you gwilki for to quick response.
thank you GregsReinventions this makes sense.
thank you for the feed back
