Not sure if this is the correct spot for this question. Does anyone know if SIenci still sells the original dust shoe. I have the new magnetic dust show which is excellant but it is too large for me to use when I surface my spoil board as it hits the side of the machine. I have the old one but it is on its last legs.
@LarryLSimmons Which machine do you have?
I have a ALTMILL 4X4. Thanks.
@LarryLSimmons I’m sure that you have checked the store - as I just did - and it doesn’t seem to be there. It may be worth contacting them directly. They may some old stock around.
Failing that, there are threads on here setting out workarounds. In short , I believe the idea is to surface all you can with the shoe on, then surface the small remaining parts with the shoe off. Not ideal, but better than nothing.
Thanks, I did reach out to them as well. in the mean time I will most likely jury rig my old one to keep using it.
