EEPROMM settings
I used the calibration tool to get my machine more accurate and have apparently really messed up the EEPROMM settings to where the machine is really inaccurate. Any suggestions for resetting these {$100,$101} ? I reset them to 200.000 and the machine just crawls. Any help is appreciated.
@1mike1 You can go here to find the default settings, or just revert to default in gSender. It’s always a good idea to export/backup your current settings before flashing with the default. That way, if things don’t go as planned, you can easily get back to where you started by re-importing the values that you saved.
Thanks for the info, I reset to default just to get straightened out. Not sure what I did, but things are running again, although a little slower than I like but I can deal with it for now.
@1mike1 Glad it worked. Are you running the long board or the SLB?
SLB, got it when they upgraded the MK2.5
