Eprom settings in g sender
I am using G sender for my Altmill but my firmware is not showing any Eprom choices at 395 and I am trying to sync it up with my Spindle. Tried resetting but nothing. Can i try Flashing back or will that cause other issues. Not sure what the problem is.
Hi Nick,
I don;t have a spindle and no SLB either so I am going on a maybe this or that.
I looked into the eeprom settings page and wondered if $9 needs setting before spindle settings are enabled further on?
Found here:
Are you connected with grbl-HAL or just grbl? That’s all I got as I don’t have an AltMill or SLB. I think from reading on here that it’s possible to connect to a SLB with grbl but it won’t work right.
Hey, you are exactly right for some reason I was on Grbl and not Grbl hall. Somehow it got mixed up. I seem to fallen into the proper setting as everything looks OK for now. Thanks for your help.
